If you still have the wheel cylinders the best bet is to get them lined with brass or stainless. White Post Restoration is one of many places that do this and they guarantee the work for life. It should run you around $75.00 per cylinder if memory serves me.
https://www.bigmacktrucks.com/topic/51286-1954-mack-b95/#findComment-381810
You can get new and rebuild kits from Wagner through NAPA. Take the wheel cylinder to NAPA and drop it on the counter. DO NOT TELL THEM WHAT IT IS OFF OF. Drop it on the counter and say "I need two of these or rebuild kits." Any parts man worth his weight will pick it up and cross reference the casting number, if you were to tell 75% of parts guys these days that it is from a Mack, they will go into vapor lock.
Edited by 1958 F.W.D.
https://www.bigmacktrucks.com/topic/51286-1954-mack-b95/#findComment-381826
Wagner still lists 2 different rebuild kits for that number. One with Dust boots, piston seals and spring. The other is all as mentioned but includes new pistons. That an odd wheel cylinder because it is off set from the mount.
The Wager number does not cross over to EIS, Rockwell or Bendix.
Edited by 41chevy
https://www.bigmacktrucks.com/topic/51286-1954-mack-b95/#findComment-381828
