  • 0
Cam replacement on E7 grey motor
Question
1 answer to this question
  • 0
You have to pull the head . They come down through the top of the block, there is a special tool that installs them to the correct depth and makes sure they are straight. His is a good time to use the tool to check the other H rings for proper depth
Answer this question...
