 any engine codes ?Charge air checked?  Ambiant air temp sensor reading correct?  Also if you put an MP8 boost sensor in It may help!we accidentally put one in a few years back it made the bloody thing into an animal However if its still under warranty be carefull!
And last week we found one with a crack in the venturi tube on the front of the engine on the back side not visible at first  we were also looking for 5 psi or so missing boost we found it there NO CODES! just some suggestions!
https://www.bigmacktrucks.com/topic/51485-mp-10-low-boost/#findComment-383276
