I have an 01 granite. New motor has 80,000 miles, truck had 443,000 at time of install. Has excessive blow by and is using or leaking about 1/2 gallon a day (10hrs). Smokes on idle grayish. Please help! Was quoted 14,000 for a motor or 10000 for rebuild.  But I’m hoping that I don’t need one!
https://www.bigmacktrucks.com/topic/51488-using-oil-excessive-blow-by/
Once you have leaks fixed and turbo inspected build a manometer and measure the blow from the crankcase. If you have 6-8" of blow your heading to the shop. Also check your air intake system for the dust leak that took out your piston rings.
Okay will do! Thanks for the reply.
57 minutes ago, Benny said:
Maybe. Would you have any suggestions on where to start first, if you don’t mind.
start pulling things apart and checking by eye and manually with air
Most things can be checked a fair way with out spending bugger all
What type of motor is in the truck ?
Paul
