  • 0
My truck won't start.
Question
I had a bad fan clutch and my truck overheated to the point it shot off. I change the engine oil and worked for about 3 weeks. Know it won' start I checked the oil and needed about 6 Ltrs. To bring it to the right level. Where did the oil go in 3 weeks. I checed voltage drop at the starter is ok.  batteries are ok. Fill the fuel filters one was empty. Should I expect a serious problem?
https://www.bigmacktrucks.com/topic/51663-my-truck-wont-start/
2 answers to this question
  • 0
when you say it wont start, and you are checking battery voltage I assume you are saying it wont crank over ?  If this is the case, you could have a cylinder full of coolant (caused by a cracked head or failed head gasket as a result of the overheating ) or you could have spun a main or rod bearing due to the low oil level .
https://www.bigmacktrucks.com/topic/51663-my-truck-wont-start/#findComment-384858
Answer this question...
