I have an 04 mack vision with a 5-9 blink
i have been told that this means that the EGR mass air flow sensor tube needs replacement ($1200).
Can someone tell me what is the negative effect of running the truck with a bad EGR mass air flow tube?
Will I cause other more costly damage?
https://www.bigmacktrucks.com/topic/51729-egr/
https://www.bigmacktrucks.com/topic/51729-egr/#findComment-385448
The short answer is, engine performance and fuel economy will suffer, reducing the amount of money in your back pocket.
https://www.bigmacktrucks.com/topic/51729-egr/#findComment-385457
THE OTHER  Short answer YES ! But Not ALWAYS  However when this happen s  usually the EGR COOLER has failed that 1200 dollars now becomes 3000 dollars ! Are u also loosing coolant? If so the afore mentioned may apply in this case you have two choices Spend the the 3000 grand or cap off the egr coolant and cap off the egr valve and bypass everything! This has been done and the effects  are negligible!
Edited by fjh
https://www.bigmacktrucks.com/topic/51729-egr/#findComment-385500
