Looking for the proper way to remove the cab air bags from the bottom of the cab.  I have them out of the base (held in by round retainer rings) but unsure if they bolt or twist onto a stud on bottom of cab.  Also is there a steel spacer that goes between the bags at the top and base?  I ask because there was a large piece of rust scale with a hole in the center that came up off the base of the bag and crumbled apart.  Any help is appreciated, thank you!
https://www.bigmacktrucks.com/topic/51850-r-model-cab-air-bag-removal/
