hi all wondering if anybody can help me I have a 1975 and a 1986 rd600 mack 6x4 and i am trying to find out the maximum gross train weight gtw of these vehicles i have been on to mack museum but they don' have it all they have is the build sheets and its ot on there
any help on this would be great
Thanks richard
https://www.bigmacktrucks.com/topic/51865-1975-mack/
GTW sounds similar to our GVW/GVWR (Gross Vehicle Weight Rating).
Here in the US, the current GVW of a typical highway tractor trailer combination is 80,000 lbs.  Are your trucks set up as tractors?  Tippers?
https://www.bigmacktrucks.com/topic/51865-1975-mack/#findComment-386633
hi thanks for your reply and yes your gvwr is the same as our gtw  in england my lorry are ex house movers from Canada and set up as tractors I've posted a picture of my set up in england  there is no stamps on my vehicle plate at all so trying to find out so i can get it legally stamped up
Thanks richard
https://www.bigmacktrucks.com/topic/51865-1975-mack/#findComment-386676
From the build sheet there will be a front and rear axle arrangement identification.
Example:  Front axle  FAW 536C  10,500 lbs.  Rear axle  SWS 56C  34,000 lbs.
Example                       FAW 537C  12,000 lbs                       SS58C     58,000 lbs.
What does your build sheet say for axle arrangements?  That will indicate how it was built originally.  Things might have been changed on the truck but at the moment, that is unknown.  Should be able to narrow this down so you will have some info.  The info is stamped on the axles but checking the paperwork is easier to examine first.
https://www.bigmacktrucks.com/topic/51865-1975-mack/#findComment-386695
