I'm thinking its not on firewall . it's a black box mounted on the back side of the metal  support bar that runs from the dash to the door post where the door hinges as on the driver side. It also does the turn signal clicking and power divider buzzing when engaged and engine shutdown buzzer
https://www.bigmacktrucks.com/topic/51875-low-air-buzzer/#findComment-386779
  • 1 month later...
  • 2 years later...
18 minutes ago, SupraJay87 said:
I installed a new buzzer for my 94 RD688s, it works for the signals and flashers but it doesn’t come on for low air pressure, I was put out of service for it. I need help 😭
Is your low pressure light working?
Most of the time it's from guys kicking the wires off the air PSI sensor manifold down by your feet and then later putting them back on the wrong sensors.
https://www.bigmacktrucks.com/topic/51875-low-air-buzzer/#findComment-458362
I was sure only one had to work, light or buzzer. But thats in Illinois, the corrupt state.
Edited by wilbur
https://www.bigmacktrucks.com/topic/51875-low-air-buzzer/#findComment-458688
