There are 2 solenoids, one at the rear of the oil base pointing down--that is the piston cooling jet control solenoid. The other is nearly at the rear but pointing to the frame rail--that is the oil cooler thermostat solenoid. Check for oil contamination in the connector, clean with electrical contact cleaner and see if the fault goes inactive.
  • 4 weeks later...
