If you have the hard start problem but engine run fine , the sealing surface on the injectors sealing surface to the cup could be pitted to the point that it wont reseal with just a new cup. Mack has guide lines on this. Pretty much , if the sealing surface is pitted you replace the injector.
https://www.bigmacktrucks.com/topic/52230-cup-seals-injectors/#findComment-389964
