If you're not overloading the axle or abusing the truck in any other way I'd guess it's a defect.
https://www.bigmacktrucks.com/topic/52306-broken-wheels-studs/#findComment-390462
Is it 10 stud or spider hubs?
My understanding is the hub only locate the rim while installing, and the nuts clamp the rim in place and it shouldn't really be running in the locating arms. Of course I may be mistaken in my knowledge
I had a mate with worn cleats that kept breaking studs. If you have 10 stud then this obviously won't concern you.
Edited by Timmyb
https://www.bigmacktrucks.com/topic/52306-broken-wheels-studs/#findComment-390519
Front load refuse rig? You running the Steel or Aluminum rims?
Edited by 41chevy
https://www.bigmacktrucks.com/topic/52306-broken-wheels-studs/#findComment-390528
 Wonder if the install of the studs damaged them. Seen it happen with "short cuts"
https://www.bigmacktrucks.com/topic/52306-broken-wheels-studs/#findComment-390530
its a  front load   refuse truck  10  stud hubs    with  new style   axle    thread   on hub cap    we    tried    replaceing hub    still breaks the studs
 in a couple of weeks     it has  new    aluminum   wheels   cheap  china  steel ?
https://www.bigmacktrucks.com/topic/52306-broken-wheels-studs/#findComment-390577
Possibly the hub flange surface is not true to the wheel. When the lugs are tightened it pulls the hub flange to the wheel and stresses the stud. You or the dealer can check it for run out  on the face with a dial indicator easy enough.
https://www.bigmacktrucks.com/topic/52306-broken-wheels-studs/#findComment-390585
