I just got a 1964 B-61 with a END673c engine. Don't know which oil filter it takes. I have been reading older posts and they
say that if there are 3 oil lines on the bottom of the filter canister-2 bigger than the other one-it's a full flow/bypass type.
Mine only has two lines and both are the same size. Is this a full flow filter? I don't think this year engine had that type; but
I'm not sure. They said that the full flow cartridge would be NAPA #1233 and the full flow/bypass is #1030. Do you think
either of these would work and what's the difference between these two?
Thanks J. Hancock. My canister is right at 9 in. So I probably can use the 1030. I'll remove the cartridge and check for
any numbers and can always bring it over to NAPA for a closer match.
Edited by Srays
https://www.bigmacktrucks.com/topic/52362-b-61-oil-filter/
Different.  The 1233 cartridge is about 15" tall.  The 1030 is about 9" tall.
As a double check, I would open the oil canister and get the part number off the top of the cartridge that is in there now.  Who knows what someone did in the past.
https://www.bigmacktrucks.com/topic/52362-b-61-oil-filter/#findComment-390879
I've only had this truck a few weeks and was told it had an END673c engine. It may have come from the factory with that
but I now know it has an END673 in it since the oil filter it takes is a NAPA #1554 right at 9 3/4 in. tall, with a LuberFiner
500 canister. So I think that engine is 170HP and 480 lb/ft torque.
Edited by Srays
https://www.bigmacktrucks.com/topic/52362-b-61-oil-filter/#findComment-391131
