The vent window stays together as an assembly.
To replace the vent window, the door lock cylinder needs to be removed and the three screws holding the lock to the door frame, then the inner door panel comes out and the window surround trim.  Remove the screws holding the outer window weatherstrip.  Remove the screws holding the vent window assembly.  Slide the vent window backwards for clearance and remove.
You can take the turning part of the went window out but only when all the assembly is removed from the door. You also can pull the glass off its frame if you really want. i had to combine parts making a good one of 2 or 3.
