Hello, my truck says evaluating dad quality 8kph limit removed and it will not go out. I have one engine code 1231-9 ecm missing signal from acm. I have changed both nox sensors, dad pump and harness, the acm, checked the wiring up the frame into the ecm.  I have power and ground at the acm. Changed the power cable end at the batteries for the acm and checked the fuse.  Seems like a datalink issue. Any ideas??
https://www.bigmacktrucks.com/topic/52450-def-quality-being-evaluated/
There is a tool for assessing the quality of def. The quality of the def will throw codes. I’ve seen our shop use the “scope” to assess the quality of the def.
