Been trying to get the heater fan to work on something other than high. Thought it was the switch, no biggie. Problem is the connector is melted in the center. Mack recommended changing the wiring harness. Problem is, it goes into the dash and goes around some gizmo and I can't find where it goes from there. How do I change this thing out without tearing the entire truck apart?  It's a 2004 Mack CX
Edited by Al and son
https://www.bigmacktrucks.com/topic/52491-heater-fan-wiring-harness/
You won't melt the connectors if you add a relay to the system.
  • 3 weeks later...
