Looking for ideas to seal some holes up.   What is out there to go around the steering column where it meets the floor?   What about clutch and throttle linkage?    It's for my b67, I don't know if things are a little diffrent between that and a standard B.
https://www.bigmacktrucks.com/topic/52580-i-need-some-rubbers/
Restoration Specialities has a Mack pedal grommet.  MTPG1
I have never checked the size to see how well they might fit.  A little pricey to me.
http://www.restorationspecialties.com/2015Catalog/60.pdf
I had some plastic universal type pickup mud flaps that I cut up for homemade grommets.  I could cut them fairly tight and the material didn't seem to "grip" the metal of the pedals as they went up and down through the floor.  Put them down first, then some jute type sound deadener and then a rubber floor mat.  They stay in place and seem to do a pretty good job at keeping dust and wind from getting inside.
The column on my truck was a decent fit but used the homemade grommets on fuel and clutch.
https://www.bigmacktrucks.com/topic/52580-i-need-some-rubbers/#findComment-392567
