I've patched/welded on mine for years.  Until I ordered new Aluminum tanks last year!!  No more leaks  LOL!!
I used to drain them down, loosen the straps and make sure the fuel was away from where I welded.  No problem.  It would find a new spot every few years, thus I replaced them.
https://www.bigmacktrucks.com/topic/52595-fuel-tanks/#findComment-392637
I used a product called redkote in a antique johndeere gas tank before.            Dumped a quart in and rolled it around for awhile then turned it upside down to drain extra out.      Worked for the tractor, but I don't think I'd use it in a road tractor due to its red color.
https://www.bigmacktrucks.com/topic/52595-fuel-tanks/#findComment-392639
Sealers should work if the tanks are clean and etched inside. Some radiator shops  will prep a tank with an electrode suspended in with a strong electrolyte solution and D.C. voltage . One of mine leaked after sand blasting . I filled it with Murphy's soap oil and  water brazed the area where the damp spot was. So far no leaks . A coating of epoxy primer on the out side may have helped some .
https://www.bigmacktrucks.com/topic/52595-fuel-tanks/#findComment-392654
coated my B model tanks with red coat, i cut the end caps off, had the tanks blasted in and out, red coated them with a brush and stayed away from where id weld the end caps on, welded caps back on then poured red coat in the tank and rolled the tank to coat the inside where the weld was. been runnin them since 2008 with no problems.
https://www.bigmacktrucks.com/topic/52595-fuel-tanks/#findComment-392700
Did you get any color bleed to the fuel?   With the jd I did it sat about a month before I put gas in it.  I still ended up with a pinkish tint to the gas for awhile in the settlement bowl.
Edited by Hobert62
https://www.bigmacktrucks.com/topic/52595-fuel-tanks/#findComment-392707
prob not, not sure if the red kote would be enough to dye diesel or not... i know i have used some kinda white kote stuff to on the inside of a gas tank and  to my surprise, the stuff ws hard as red kote but any contact with water and it flaked right off. got that at a motorcycle shop
https://www.bigmacktrucks.com/topic/52595-fuel-tanks/#findComment-392783
That was probably POR15, I've had good luck with it on motorcycle tanks, but keep in mind that you'll need a lot more for a big truck fuel tank than a 5 gallon or so motorcycle tank needs. There's also economics to consider- We spend big $$$ restoring motorcycle tanks because even if we can buy new or good used tanks, the prices are often over $1000. But many truck tanks are pretty much generic, so better to replace with new or good used than get into expensive repairs and unsafe welding on fuel tanks.
https://www.bigmacktrucks.com/topic/52595-fuel-tanks/#findComment-392790
Two years ago, I coated the inside of the two fuel tanks on my toy hauler (freightliner).  On the way to Macungie, the truck shut down on the interstate because the coating came off and plugged up the fuel line.  I changed fuel filters, and cut them open, and found more sealant in the filter.  Had to clean the fuel lines, and cut the ends off both tanks and removed all of the sealer.  Put back together and have had no more problems.  I have over 45 years working with antique cars, trucks, engines, etc., and had never had a problem before.  I will not coat the inside of another fuel tank, especially a diesel.
https://www.bigmacktrucks.com/topic/52595-fuel-tanks/#findComment-392820
