witch of the numbers on the eup is the trim code that i need to write down to have put into the computer?
exhaust manifold torque specs? replaced exhaust manifold gaskets with the metal inner ring used new studs but not the stainless on the head to manifold studs used the serrated flange lock nuts. i came up with 55 ft lbs torqued in 2 stages 25 then 55. this feels a little light for the size of studs but maybe not, i know manifolds expand and contract a lot is this the right tq spec?..............manifold to turbo stainless studs and nuts i came up with 40lbs and that feels about right to me?
