So after a $20K bull gear replacement expense I now have an issue with power.  I'm leaning toward an injector and cup problem, but I'm not sure.  The truck is a 2012 Mack Pinnacle MP8 with 560K miles.  I have to hand prime the truck every morning to avoid the long cranking start times.  Once it is started, it runs well at idle, but between 12 and 1400 rpm it feels like the truck is running over rumble strips and looses power.  Once it's past 1400 RPM it smooths out and all is good.  I pull 84K pound loads if that helps.  I also get a "check fuel filter" warning on the display at times.  It has also said there was a fuel restriction.  I have gone through three different sets of fuel filters, finally purchasing Mack filters trying to fix this.  I'm not sure where to look next, but from reading the posts here am leaning toward possible injector cup and injector issues.  Might this be correct, or is there something I'm missing?  Any help is greatly appreciated.
https://www.bigmacktrucks.com/topic/52905-and-now-this/
