There is plenty of knowledge here.  Tell us a bit more about the Mack and provide some pictures if you can.  We also have members here who can decipher your VIN if you want to provide that as well.  If you acquired it from the original owner then you may know plenty about it but if he bought it used then various changes probably have occurred to it over the years that may not be known and pictures will help.
https://www.bigmacktrucks.com/topic/53056-new-to-mack/#findComment-396249
Yes, that is correct as built. That setup was common in the 1970's to haul lightweight finish dozers to jobsites. Lot of landscapers used the setup but DOT enforcement pretty much put a stop to the practice along with license plate fees. It became cheaper to run a pickup truck and pull a trailer.
https://www.bigmacktrucks.com/topic/53056-new-to-mack/#findComment-396286
