Hi, been looking for some replacement pistons on a Mack B61 truck for my dad, and was looking for some help idenitifying the parts and where to get them, as far as I know the engine is diesel and 6 inline (673?), anyhow I tried looking for the numbers on the piston on the internet and no luck, the closest I got are finding the piston bushings wish I think are the ones we are looking for.
Please any help would be appreciated
https://www.ebay.com/itm/Sealed-Power-Piston-Pin-Bushing-for-MACK-END-673-WAUKESHA145GK-Engine-223-3488/282074279488?hash=item41acefee40:g:X90AAOSw-4BXaHT~&vxp=mtr
https://www.bigmacktrucks.com/topic/53061-mack-b61-replacement-piston/
Or 711 ci.   If you can't find the marking on the front of the accy drive, then count head bolts and size(check the corners).   They changed size/number later on.
New parts are getting to be hens teeth.
Info from Federal Mogul.  No listing on pistons.  May help with finding something that will interchange for your application.
The ENDL 673P share specs with these engines.
EN-672, END-672, END-672S, END-673, END-673A, END-673B, END-673C, END-673D, END-673E, END-673P, ENDL-673, ENDL-673P, ENDS-672 Engs.
11.0L 672 OHV Diesel L6, 4.875" Bore
2 part numbers for bushings are listed.
                                 PART NO.                   DESCRIPTION
Pin Bushing           FP-187GB138             w/2" pin dia.
Pin Bushing           FP-1759V                    Con. rod No. 367GC-468F
