Just a pointer when replacing mains. #2,3,5&6 share the same uppers and lowers. #4&7 share the same lowers but have different uppers--can't mix them because of tang location. #1 has the same lowers as 2,3,5&6 but a different upper. I have seen people put the wrong upper shell in #1. The wrong one will fit in #1 but you will loose all thrust plus the oil feed is in a different location on #1.
https://www.bigmacktrucks.com/topic/53133-2003-etec/#findComment-397102
great pointer, will look out, bought the manual from mack
https://www.bigmacktrucks.com/topic/53133-2003-etec/#findComment-397131
