Driving the dump truck today out the blue starts to smoke white smoke skipping running rough..tried the codes i get 6/6 fuel control module but if that was the case would the truck run at all..how can I check the injectors..it has the eup injectors as well as the others i guess is a good way to word it..
https://www.bigmacktrucks.com/topic/53324-2000-mack-e7-rd688-injector-or-ecm/
Ok little update today..mechanic cracked all injection lines all are pumping fuel last 4 cylinder are cold ..towed to his shop going to put a test ecm on see what happens may put manifold and turbo to see really what the cylinders are doing ..hopefully ecm will fix the problem
  • 3 weeks later...
