Another AC question;  Today I removed the clutch from my AC in preparation toward adding a ring gear to the flywheel.   On loosening the bolts that hold the clutch to the flywheel a wire came out of the space between the two parts.   This is about .100" DIA.  & makes a full loop of the flywheel.  Is this normal or is it a spacer added for some reason?      With that in mind, how thick should the clutch lining be?       I have some extra AC clutch plates that look to be NOS - the friction material measures .260"  while the one in the truck measures .200" wit no appreciable wear showing.
Thank you for any assistance,
Jack
Edited by Jack Innes
https://www.bigmacktrucks.com/topic/53443-ac-clutch/
