I have a 93 rd with an e7 400.   We overhauled the engine last winter.   It acts like it doesn’t have any power now.   So I had the injectors tested while I did the head retorque,  they are perfect.   I’ve acquired a pro link 9000 scan tool for a Mack and have narrowed it down to the timing is not advancing, it actually retards when accelerating.  I have 12 volts at the econovance solenoid. I powered the solenoid with 12 volts and it runs better and shows timing advance on the scan tool.   I tried changing Ecm and Bosch module no luck.  I’ve also changed temp senders and manifold air temp sender, and Reset tem sensor,  but nothing changes still no advance after idle.   So my question what’s telling it to not advance?
