It’s more than I have. I have a light steam out of my oil fill tube and my crankcase breather vent is more of a steady steam. You gotta hook up a manometer to the crankcase breather vent and run it at full load and see if it’s within spec. Look under the power steering pump, there will be an 1.5” or so tube running down and you will see some steam coming from there too.
I’m going off of my experience.im  sure the other guys on here will chime in. These guys are like genius’s when it comes to trucks, especially Mack’s
https://www.bigmacktrucks.com/topic/53672-blow-by-e7-350-2002/#findComment-401365
Also you will note that you have a slight puffing coming from that fill tube indicates to me you have a cyl not sealing well, crack some fuel lines and see if you can change the demeanor of that puff ! If you have the rigging to do a cyl cut out test with the mack software .
Just a thought!
https://www.bigmacktrucks.com/topic/53672-blow-by-e7-350-2002/#findComment-401419
Mack corporate always told us not to worry about blow-by . Oil consumption is what they looked at. My friends 99 CL had bad blow-by from the 500,000 mile mark up to a little over a million mile mark when we over hauled it. Used a gallon of oil per 8,000-10,000 miles. Steady  stream of blow-by don't bother me. It's the puffing blow by you gotta watch out for.
Edited by Mackpro
https://www.bigmacktrucks.com/topic/53672-blow-by-e7-350-2002/#findComment-401432
First I heard that. Thanks for the tip.
my old mechanic told me I think it was CAT, that they don’t recognize blow by
https://www.bigmacktrucks.com/topic/53672-blow-by-e7-350-2002/#findComment-401433
