NOSE CONE AND GRILL REBUILT ON 42 DE
3 minutes ago, j hancock said:
Ahhh....  the old Bondo surprise!
Appears that you are doing an excellent job bringing it back into shape.
Well put "BONDO SURPRISE" I discovered the bottom of the doors had been filled with Great Stuff foam insulation and covered with bondo on the outside, looked nice at first glance but was causing the doors to rust out from the inside, the foam was acting like a sponge and retaining moisture. We learn something everyday.
It is irritating that Ford still uses some sort of foam between the outer skin and the wheel wells on their pickup truck bodies.  There is a factory hole on the inside of the body near the top rail and I use it to squirt used hydraulic oil onto the foam.  I would rather have the foam filled with oil than water.
This may have changed with the use of aluminum.  Haven't checked it out.
