The 63 B61 Thermodyne, 20 speed,I just got running has a noise / squeak I can't figure out. Put in this forum because I'm not sure where it's from. Engine running, either stick in or out of gear, moving or not. Get louder when moving, mostly in cab. And the wierd part, gets less when I'm sitting in the seat when not moving. Not from the engine, thinking maybe a cab or trans mount? Clutch in or out, no difference.
https://www.bigmacktrucks.com/topic/53929-drivelone-noise/
Those are the worst...besides electrical
make sure it has been greased properly..especially the throw-out bearing
this will remove moving parts noise
next, just start shaking EVERY part of the cab
https://www.bigmacktrucks.com/topic/53929-drivelone-noise/#findComment-403216
How is the rear cab mount area?  Mine was patched up loosely by previous owner.   I welded the new pieces in solid.  Grab cab(with engine off) and rock it.
https://www.bigmacktrucks.com/topic/53929-drivelone-noise/#findComment-403508
  • 1 month later...
