wiring the starter for 1956 B63 Mack Truck
Adding more info ...hope I can explain it correctly...there are 2- 12 volt batteries  and 2- solenoids ...what we can figure is one battery actifies(sp) one solenoid and the other battery does the other solenoid...someone said its a parallel hookup ? whatever that means...
How do we check the solenoids ...
We rebuilt starter by putting new brushes in ...
Here is a diagram for the series parallel switch.  Hopefully previous work on the truck hasn't messed up the wiring too badly.
Note that one diagram is for a positive ground system and the other is for negative ground.
https://www.bigmacktrucks.com/tutorials/article/70-wiring-schematic-for-series-parallel-switch/
