I am considering putting the TRXL1071A in my 2003 RD688s, I have a Eaton RTOF 8 LL now.
i have the AMI 370 so I don’t think I’ll have  a issue with the extended range nature.
i like the 23.08 low gear,5 speed and the multi speed reverse features of this trans. the direct 5 th will work fine with my set up.
my question is what all would need changed, I assume a bellhousing for a Mack trans would be needed and some driveshaft work as well. Is there a yoke that would work that has the 16 tooth ring for speed sensor?
Are there any software adjustments I could make to optimize this set up ?
i realize I may have to fabricate a mount for the sensor .
thanks in advance for any info
https://www.bigmacktrucks.com/topic/54084-trxl1071a-in-a-2003-rd/
