26 minutes ago, Bullheaded said:
Spotted this at a pit I am hauling out of in northern Ontario, Canada. I was kinda surprised to see an Anthem used for this application with wide base steers.
I'm sure it's a "Dumb" Question,!!!
But, why do the Trailer axles have Different Spreads?? A big, No No.. here..
Because those that matter...
don't mind...
And those that mind....
don't matter." -
https://www.bigmacktrucks.com/topic/54177-heavy-spec-anthem/#findComment-405316
I think it looks better like that with the big steers and flat top than it does as a highway truck.
I just wish they could find a designer than can come up with some better looking air intakes than those screen doors on the sides of the hood. At least those goofy mirrors can be deleted.
https://www.bigmacktrucks.com/topic/54177-heavy-spec-anthem/#findComment-405401
This truck is owned by a gentleman who owns a fleet of Petes and KWs.  Don't get to excited about Mack getting into this Paccar fleet. The son of the owner is an apprentice at a Mack dealer and convinced Dad to buy it. They still have Paccar products ordered and on the way.
It's only a 14.6 and 46 spec. Mdrive blah blah. Lots of elecectrical issues with that one already. The owner of the fleet drives it.
https://www.bigmacktrucks.com/topic/54177-heavy-spec-anthem/#findComment-405471
On 9/3/2018 at 11:48 AM, Lmackattack said:
im still not sold on them. even when they are "dressed up" they still look like a entry level plastic truck. The look of them are just not what I would want in a truck. the body lines are all wrong with the hood. it needs to be a little flatter on top and longer so that the engine is under the hood not the cab. the small hood with a engine stuffed under the cab just screams $$$$$ every time it needs a simple repair.The air tank set up is not pleasing to the eye. Stack location behind sleeper is good for aero but should have other options.
Engine location is no different than on an "old" pinnacle.
https://www.bigmacktrucks.com/topic/54177-heavy-spec-anthem/#findComment-405497
Kevin posted a couple days ago that the Scania V8 would need a wide front frame like Macks used to use due to it's width. I looked up the V8's dimensions and I'm afraid he's right, and with inline 6s dominating the market here there's no incentive for truck makers to build a wider or drop front frame. So while you could probably fit a Scania V8 in a CL or the other chassis that hosted the Mack V8, It looks like the Scania V8 won't fit any current International chassis. Wonder if the tooling for the drop front frame section from the Transtar days is still around...?
https://www.bigmacktrucks.com/topic/54177-heavy-spec-anthem/#findComment-405523
Those big steers are just show. You can get up to s 16f axle on an Anthem.
https://www.bigmacktrucks.com/topic/54177-heavy-spec-anthem/#findComment-405544
To bad Volvo-Mack does't offer the Cummins ISX15 , 400-600 horsepower with up to 2050 pound-feet torque. Any idea way Volvo-MACK won't offer it?
https://www.bigmacktrucks.com/topic/54177-heavy-spec-anthem/#findComment-405571
  • As stated above the pinnacle can be ordered with the Granite chassis. So why aren't there more heavy duty pinnacles and granites sold as tractors? Hmm let's put on our thinking caps.  Why is Pete/KW-WS-Shaker kicking Mack's ass. NO BIG BORES ALLOWED IN THOSE SHORT HOODS PERHAPS !! :wacko:
Edited by james j neiweem
https://www.bigmacktrucks.com/topic/54177-heavy-spec-anthem/#findComment-405593
Price....price.....price......and the lack of a X15/DD15/DD16 competing powerplant.
https://www.bigmacktrucks.com/topic/54177-heavy-spec-anthem/#findComment-405600
