The pinion seals must be the same as CRD92/93 carriers had which were used on R-models and many newer Macks. Try checking Stemco web site. They have online catalog for hub and pinion seals with sizes and discription.
From what I have in my copybook you seals should be :
Front input Mack 88AX458 Stemco 429-0002 4.5x3.5"
Front output 88AX456 429-0008 3.537x2.751
Rear input 88AX457 429-0009 3.996x2.751
If you were saying your truck is B61 I'd say go with the numbers I posted. But you B81SX might have heavier carriers . So better slick under the chassis with a caliper and relate the sizes.
Vlad
https://www.bigmacktrucks.com/topic/54207-axle-break-down/#findComment-405543
Vlad
A B81 could have the 50,000 rears, takes a different carrier, different seals maybe.    terry:MackLogo:
https://www.bigmacktrucks.com/topic/54207-axle-break-down/#findComment-405549
https://www.napaonline.com/en/p/NOS99269
"N" Nominal Dimension 2.750 in. / 70.00 mm
Brand Name NAPA Oil Seals / SKF (CR)
Fits Shaft Diameter 2.750 in. To 2.756 in. / 69.85 mm To 70.01 mm
Flange Diameter 3.125 in. / 79.38 mm
Installation Dimension 1.250 in. / 33.32 mm
Seal Surface Width 1.125 in. / 28.58 mm
Speedi-Sleeve I.D. 2.75 in.
Speedi-Sleeve Width 1.25 in.
UNSPSC 31171509
https://www.bigmacktrucks.com/topic/54207-axle-break-down/#findComment-406213
