  • 0
Question
1 answer to this question
  • 0
Hope you have it fixed by now, if not and you see this, please answer back and I will check the code. If what I think it is, it has to do with the dosing system of your def fluid,but since I’m curious now, will look code up tomorrow and try to put and answer back in, sorry I’m not a computer and I can’t remember all of the code numbers since they keep changing
And you thought only NASA had rocket scientist!!!!
https://www.bigmacktrucks.com/topic/54219-fault-code/#findComment-412862
Answer this question...
