I am thinking about trying to fire up this old girl. It has a EN 438. What oil/filter do i need and spark plugs and wires. Is there anything that i need to watch out for? The throttle cables seem free. I was gonna use the batteries from my backhoe to use they are a type 24 500 cca. Would those be ok to test the truck?
https://www.bigmacktrucks.com/topic/54248-b422/
Also see if it is positive or negative ground
https://www.bigmacktrucks.com/topic/54248-b422/#findComment-405844
7 hours ago, Maddog13407 said:
its only 12 volt,one hot 12 volt will turn it fine. as for filter and wires, id see if it runs first then screw with the rest.
the guy said it has been siting for about 10 years. so i would like to change the oil before I fire it up.
How can i tell if it is positive ground?
https://www.bigmacktrucks.com/topic/54248-b422/#findComment-405861
If I remember right, it will not much matter if you switch up polarity on accident being such simple machines. You may have the voltage/amp gauge read backwards or something but as long as it is a 12v system and not a 6v I don't think you will hurt anything.
https://www.bigmacktrucks.com/topic/54248-b422/#findComment-405918
