New to me truck so no experience with this engine or a fan clutch with no air going to it.
The fan seems like its spinning hard all the time. When the engine is off I can easily turn the fan over by hand with moderate resistance does not spin freely. The fan clutch looks like a thermostat operated unit, no air or sensors.
Should I be able to turn this over by hand when off and cold?
Any help would be appreciated!
https://www.bigmacktrucks.com/topic/54312-help-diagnose-fan-clutch-e7-300/
It does not have A/C unfortunately, I called up the local diesel parts and gave them the vin. They said they have a few in stock rep on the phone was very knowledgeable mentioned that when they go bad theyre usually very hard to turn or locked up. I think I might go ahead and run the truck for a few weeks and see if I see the temp climb, if so I'll go ahead and swap one on. The price was surprisingly low $170.
