I have an odd one. I'm doing a mirror upgrade for our plow trucks that use a tow plow. Swapping the right stationary mirror for a motorized one. Both left and right mirrors heated of course. The heated mirrors won't operate. I unplugged both to see if the switch would light and it did....1 time. I pulled up the wiring diagram and everything I see is checking out. I have power to the switch at #2. When I press the switch #4 terminal lights like it should. I swapped the relay with another one with exact part number. The HTD mirror fuse at f15 is good. I replaced the switch just because I have one. Any help would be appreciated.
https://www.bigmacktrucks.com/topic/54404-heated-mirrors/
I would go back to the basics. Take the two heater wires from the mirrors and put 12V to them and feel if there is heat. If not the elements ate burnt out. On the right mirror motor take the two wire to it and see if it moves them reverse the wires and see if it moves the other way.
As for switches get the volt meter out and start checking if the correct terminals have power, for switch position. If all that checks then it is the wiring between the mirrors and switch or your wires are on the wrong terminals.
https://www.bigmacktrucks.com/topic/54404-heated-mirrors/#findComment-406649
Not sure if that's a new enough Mack to have CAN bus wiring, but with CAN bus if there's more current draw than the computer expects it may shut down the circuit or do weird stuff. Probably should check the Mack body builder manual which I think is a free download if you don't have one.
https://www.bigmacktrucks.com/topic/54404-heated-mirrors/#findComment-406657
According to the wiring diagram, when the switch is turned on there should be voltage at pin87 on the heated mirror relay. The instrument cluster controls the relay ground circuit (pin 86 on relay). The instrument cluster may also have a heated mirror icon which may be why the switch power (pin 4) goes to the cluster plus it acts as a signal to turn on the relay ground. It possibly could be a feature that needs to be enabled through the dealer or using PTT2 if you have it.
https://www.bigmacktrucks.com/topic/54404-heated-mirrors/#findComment-406780
turckster, I concluded that the instrument panel controls the ground circuit. But you cannot just ground that circuit, you'll pop the fuse. ZDB I felt I should have a lit switch with out the mirrors plugged in. Here is what I have.
At the switch I have power at terminal 2 with the ign on.
When you push the switch I have power at term 4 on the switch, and that power goes to term 27a on the instrument panel.
With ign off I have power at pins 85 and 30 at the mirror heater relay. With the relay plugged in I have power at pin 86 at the relay which sends power to pin 22b at the instrument panel.
I have continuity from pin 12 on the switch to the positive at the mirror. The Ground at the mirror is good.
ALSO.... I took the dash, the relay and the switch and installed them all separately in another 2013 gu and every time the heated mirrors worked.
I'm so lost on this
https://www.bigmacktrucks.com/topic/54404-heated-mirrors/#findComment-406785
When you turn the heated mirror switch on you should have voltage at pin 87 at the heated mirror relay. When there is voltage at pin 87 there should also be voltage at pin 12 on the H/M switch (for the lighted part of the switch). If you don't have voltage at pin 87 (relay) then there is a wiring issue somewhere. You have verified the components(switch, inst. cluster, mirrors and relay) are ok. Measure resistance from pin 4 (switch) to pin 27A (instr. cluster), should be 0-5 ohms. Measure resistance from pin 86 (relay) to pin 22B (intsr. cluster). Wiggle the wiring to see if the resistance jumps around. If those circuit look ok jump pins (relay) 85 to 87 and 30 to 87 , if the mirrors heat up then you know those circuit are ok.
https://www.bigmacktrucks.com/topic/54404-heated-mirrors/#findComment-406847
ok, so I measured resistance , pin 4 to pin 27a... .5 ohm. Then pin 86 to 22b... 5.0 ohm. I wiggled the harness no changes. So then with everything connected , ignition on I pressed and held the switch and wiggled the connection at the dash panel and the light came on. So I have it positioned where it'll come on every time (so far ) but what would you recommend. I had my suspicions early on that the dash panel itself was bad. But I don't know what to do now. Should I order a dash unit? If I order a dash panel will it need to be programmed at the dealer?
https://www.bigmacktrucks.com/topic/54404-heated-mirrors/#findComment-406982
When you say dash unit do you mean the instrument cluster? If yes I would think the issue is the harness connector terminal. Either the 27a or 22b terminal is loose on the pin. If you are careful you can remove the terminal from the connector and carefully pry the contacts. The reason I say that is you tried this cluster in another chassis and it worked, correct?
https://www.bigmacktrucks.com/topic/54404-heated-mirrors/#findComment-407091
Actually I did pull the connectors apart and pried the connector yesterday. Put it back together and turned on the mirror heat. Then I wiggled the harness at the back of the panel and I could not get it to go off. Thanks for the help turckster!!
https://www.bigmacktrucks.com/topic/54404-heated-mirrors/#findComment-407126
