Don't use my truck very often during the winter months. It has four 6 volt batteries. negative ground. Is it possible to attach battery tender, if so would like some instructions on how to do it. I start the truck through out the winter using the block heater.
Victor
https://www.bigmacktrucks.com/topic/54528-battery-tender-possible-on-58-b-61/
Are the batteries wired together to make (2) 12 volt batteries?  If so, connect the 12 volt Tender to charge the two batteries together.  After a couple of weeks switch to the other set of 2 or buy a second Tender.
Tender makes a 6 volt version if you want to maintain separately.
Tenders work well and you can check out their connections info on the link.
https://www.batterytender.com/Connecting-Chargers
