I am trying to find a input shaft for a TRQ7210  Quadraplex  transmission. It needs to be for a twin disc clutch  2 inches in diameter  10 spines and 25 teeth. This is the part number at least this is what was given to me.  764KB395A  Thanks in advance.
https://www.bigmacktrucks.com/topic/54583-trq-7210-input-shaft/
I was looking back about 15 years ago for one. The only way even back then was to find a transmission with the twin disc clutch input shaft. There is a different bellhousing for the twin disc as well. Not the same as a single disc clutch. Don't know your setup but South Bend Clutch can beef up the springs and use ceramic pucks for better torque capacity for ether clutch.
https://www.bigmacktrucks.com/topic/54583-trq-7210-input-shaft/#findComment-408087
