Good afternoon, looking for help on a CXN 613 with a few codes. SID 277 FMI 9 EGR gas mass flow sensor, perform service as soon as possible, abnormal update rat. SID 27 FMI 4 Actuator for VGT, current too low or short circuit caused by malfunction, PID 412 FMI 9 Recirculated engine exhaust gas temp, abnormal update time, SID 236 FMI 4 Supply relay, current too low or short circuit caused by undervoltage.
I'm not sure where to start but I think I'll begin with the low voltage codes. The truck lost power when these codes were active, they are now inactive and power is restored. Any thoughts?
https://www.bigmacktrucks.com/topic/54640-05-cxn-613-egr-issue/
All of these faults are voltage related. Fuse 38 powers the EECU, make sure it has battery voltage (12+ volts). Fuse 38 gets its power from the starter relay. Make sure all battery, starter and ground connections are clean. Checked the ground relay connections on the firewall as well.
https://www.bigmacktrucks.com/topic/54640-05-cxn-613-egr-issue/#findComment-408394
  • 3 years later...
