  • 0
AC fan controller only works on high
Question
I have a 2013 Mack CHU613 tractor with the ac blower only working on high. I swapped controllers from another truck but didn’t fix it. Is there a resistor or something I’m missing and if so could you please help me with a location. Thanks
Edited by arodiesel123
https://www.bigmacktrucks.com/topic/54645-ac-fan-controller-only-works-on-high/
2 answers to this question
  • 0
If the blower motor only works on high the your correct that it’s usually the resister. Pull off the lower kick panel in front of the passenger seat (4 -T27 screws). You can’t miss the resistor. Large connector and 2 small screws holding it in. We also see lots of burned up wires on the back of the control panel  that cause issues. This is a very good time to replace the cabin air filter while the cover is off. Mack has a new style filter out now that like house HVAC filter.
Answer this question...
