Attached pictures of my 1960 B73 "The Fugative" restoration that is ongoing, it is done now till spring. It is all covered up for the winter.
All i have left is to reseal the nh220 cummins cylinder heads, install the flooring, fenders and install the new lights and wiring i have.
https://www.bigmacktrucks.com/topic/547-60-b73-restoration-on-going-pictures/
Looks great, I really like what you did in the cab Thanks for sharing. I'd like to find a old dm 800 for a fixer upper. Tim :thumb:
Thanks.
Like i said i have to install the rubber flooring that i am planning on getting soon from Watts, put the trim on, fenders back on, rewire the front, change all the fluids and filters and reseal the heads. Winter has set in and at that time;my time is limited so i will continue with the project in the spring.
The project has taken about 9 months so far, the cab didn't come off but worked around it. I have a before pictures i will post.
I would like to find some grounding/wiring terminal posts that mount on the fenders, thats what i really cannot find. 6-8 terminal ones.
Thanks.
The project has taken about 9 months so far, the cab didn't come off but worked around it. I have a before picture i will post.
Not factory looking totally, but I've seen terminal strips with screws before. Hardware store should have them. Various length/number screws.
I might have some original ones in a box, might poke around and see if I find any?
