42 minutes ago, steeler said:
Not sure of the exact spec, but should be higher. What hp mp8 is it? Can you hear any squealing noises or anything abnormal?
Ita either 445 or 425 I can’t recall 100%, I gotta check valve cover... the fan clutch has been stuck on for a while and I can’t get it to go off. I changed the fan clutch assembly and nothing changed. I scanned it with computer and had some dpf codes. Had to do a forced regen. Also had a code for engine brake module. So I changed that out but still don’t have much engine braking power. I think that’s related to the low boost... this truck just feels like it has no balls anymore. It used to be a nice pulling truck and now I can barely go 30-35 mph. I’m thinking injectors. I gotta check for a boost leak though as well
https://www.bigmacktrucks.com/topic/54728-mp8-boost-question/#findComment-408864
2 hours ago, RobM626 said:
If the vanes are dirty or clogged will t give codes? Same goes for egr.will it always give a code if it’s dirty?
The codes will never tell you specifically what is wrong. They just tell you if something is out of it's normal operating limits. You then have to diagnose it from there. I had a bad scr for quite awhile and the fault codes kept leading us back to the egr. Finally they replaced the scr and all gas been good for months.
https://www.bigmacktrucks.com/topic/54728-mp8-boost-question/#findComment-408906
I went they 3 sets of nox sensors. Had the dpf baked like 3 times. Def dosers. It makes me think a fuel problem causing it to get so dirty faster than usual. I gotta start taking stuff apart. Before doing that I was just trying to figure out where to look first
https://www.bigmacktrucks.com/topic/54728-mp8-boost-question/#findComment-408907
  • 1 year later...
Fan is stuck on ????  Air clutch ?    I've found when a fan stays on and the engine doesn't run at the right temperature it never gets all the condensation out of the EGR cooler.....which makes it try to open the EGR valve more (and bleed off manifold pressure)  Temperature is critical to everything working and if it's too cool it won't really think it has anything wrong with it. (no codes)  If it is an air fan clutch ??  often the out of tank regulator (cut off) can be malfunctioning ....again, no codes.
https://www.bigmacktrucks.com/topic/54728-mp8-boost-question/#findComment-453274
