Check all return lines from injectors, also the fuel delivery pump has two small plastic check valves, if they are not sealing it will lose it's prime.   terry:MackLogo: I suppose you should check all fuel lines!
Can someone help me identify my injector pump. The engine is a EC6-350
This is the tag on the pump
Which parts are the check valves on this schematic
https://www.bigmacktrucks.com/topic/54779-1985-rs688lst/page/2/#findComment-410980
  • 1 month later...
According to the information I received from the Mack museum the passenger side power window unit shown in the photo was factory installed. This unit is on its last legs and needs to be replaced.
Does anyone know where I can get a replacement unit?
Was there originally a cover on the unit?
https://www.bigmacktrucks.com/topic/54779-1985-rs688lst/page/2/#findComment-415180
I didn't realize those were installed at the factory. My 85 RD has one . I will take a pic of the cover that goes on it. I always thought it was something aftermarket because I had an international with the same thing.
Keith
https://www.bigmacktrucks.com/topic/54779-1985-rs688lst/page/2/#findComment-415263
You never said if the truck was hard to start both cold and warm? How does it start if allowed to set for about four hours after running?
Once started it is easy to start after 4 to 8 hours it does crank more than I like but nothing like first thing in the morning
https://www.bigmacktrucks.com/topic/54779-1985-rs688lst/page/2/#findComment-415315
Right now I can't work on the truck until my knee heals from surgery last week
So right now I am planning the attack on the fuel system, looking for a source for my power window motor and a 60" sleeper
My bride was nice enough to take me to look at some cars over the weekend
https://www.bigmacktrucks.com/topic/54779-1985-rs688lst/page/2/#findComment-415473
Better watch out!  Moma appears to be giving you the signal she is going to slug you if you don't put the camera down.
Sorry about the knee.  Probably out of warranty at this point..
https://www.bigmacktrucks.com/topic/54779-1985-rs688lst/page/2/#findComment-415517
There's a warranty?
How long is that for?
This was my good knee
https://www.bigmacktrucks.com/topic/54779-1985-rs688lst/page/2/#findComment-415570
14 hours ago, Quickfarms said:
There's a warranty?       There WAS a warranty.
How long is that for?        Warranty lasted until about 2 weeks before it started giving you issues.
Hope the healing process goes well.
https://www.bigmacktrucks.com/topic/54779-1985-rs688lst/page/2/#findComment-415607
The knee is healing and I am going stir crazy not working on my projects and dealing with my clients.
Today I installed a pressure gauge into the existing port on the secondary fuel filer that is after the lift pump.
I tried to start the truck and it cranked for a while then lit off but died
I repeated this
On the third try the batteries were getting really low so it was time to disconnect them and charge them.
So much for today, tomorrow is another day
https://www.bigmacktrucks.com/topic/54779-1985-rs688lst/page/2/#findComment-415973
today I got the truck running with the pressure gauge in the secondary filter.
I ended up checking the fuel filters and the primary was 1/2 full and the secondary was about 3/4 full so I toped them off, added about 9 gallons of fuel, and it was able to be started.
The fuel pressure is about 16 psi at 800 rpm and when I increase the rpm's it goes up to about 21 psi
c80d74e27924cd60bff74908779a11e8.jpg&key=31c6f8d300e92d929a6afe9433829ea6cfe0c289eeec8f9de33c9fd087837944
When I shut the truck off it drops to zero by the time I climb down and get around to the filters
There are to visible fuel leaks any place that I can find
Any thoughts where to check now?
Several posts to this topic on or about 2/9 about this starting issue have disappeared!
Who deleted them? And why?
https://www.bigmacktrucks.com/topic/54779-1985-rs688lst/page/2/#findComment-416011
Have you looked at the inlet (check) as Terry suggested above?  It is to keep the fuel primed in the system.
The author of a post can also delete them.  As to why, I don't know.
https://www.bigmacktrucks.com/topic/54779-1985-rs688lst/page/2/#findComment-416045
Not yet
Will a lift pump still pump if the check valves are bad?
If the check valve is bad the efficiency of the pump should be greatly reduced.
I was hoping that the fuel pressure gauge would give me some instead to the condition of the lift pump.
The nice part about this truck is that the fuel filters are readily accessible sitting on the outside of the frame
This makes it a project to get to the lift pump that is now hidden behind the fuel filters.
Looking at it it looks like the best way to get to the lift pump is to remove the fuel filters for access.
I am to the point of being frustrated and thinking about just replacing the lift pump and all of the fuel lines
Does anyone know what the PAI part number for the lift pump and rebuild kit?
https://www.bigmacktrucks.com/topic/54779-1985-rs688lst/page/2/#findComment-416052
Best to confirm your numbers with a PAI dealer for the pump or kit.
"Thinking" the kit is EKT-2221 and the pump is ESP-3581.
The fuel psi specs are 17-31 for your engine.
Where did you find those fuel specs?
My manual does not cover the EC6 350
https://www.bigmacktrucks.com/topic/54779-1985-rs688lst/page/2/#findComment-416321
