6.2 V8 Chev diesel
mrsmackpaul
I was helping a mate pull one of these motors out of his Toyota Landcruiser yesterday
Anyway we pulled the motor right apart and his son who is engine machinist is going rebuild it
After we had it all apart I was watching a YouTube video on these motors and it says that the push rods are harder one end than the other and to mark the push rods as they come out
Well we never did oop's
Does anyone on here know of a way pf checking push rods to find which end is the hard end ?? And if not , how critical is it with push rods ????
The You tube  video that mentions about the push rods
Any advise or help appricated
Paul
I found this description for the pushrods
This pushrod has an actual length of 8.845 inches. It is made of .375 diameter steel tube. It is tipped with one welded .375 diameter M-4 tungsten steel ball (copper flashed with hole) and one welded .375 diameter steel ball (with hole).
According to this description the copper flashed end is the hard end.
How long the copper will last is anyone's guess but they are probably really just worried about the assembly line
5 minutes ago, mrsmackpaul said:
Unlikely to happen but you never know
Paul
When you get to mahogany row, bring back the RW, R and B
The copper lasts long enough to set a matched wear pattern to each rocker arm point. GM suggests that you keep them in assembled order to the rocker and the lifter. Don't know many who do that, even GM techs.
The hardened ball is supposed to save them both from damage/ excess wear of the push rod and rocker from miss adjusted valve lash. GM learned that with the first gen Olds and Caddy diesels.
Edited by 41chevy
