Turn in a driveway this morning and hit a bump truck just lost all power only idle to 900 code 6 4 had that happen before took batteries lose no more problems..today nothing still no power I took the gray triangle shape plug apart with the green yellow and black wire pull ecm fuse let truck sit no battery hooked up even took the plugs off the computer on the passenger side of motor nothing..just went out on job ..first day and 1 hr on new job..Smh  ..anybody got any ideas to try right here at Christmas is not a good time to be out of work..or even get run off the job..any help is appreciated thank you
https://www.bigmacktrucks.com/topic/54918-2000-ed-e7-just-stopped-pulling/
11 hours ago, Moparmike said:
Can someone tell me where all the truck grounds are on a 2000 rd I'd like to check those as well
Do a google search for “Mack Service Bulletin SB-221-032”. It will outline a complete ground cleaning and check.
