What lights does the cl lamp switch activate? What lights does the light switch activate? I have all brand new lights on the roof all grounded. I have the 3 center lights working. With the light switch. The outer lights and the dome light do not work. I have power at booth poles of the cl switch when in on position. No power at the outer lights. If my memory is correct the cl switch turns the outer lights on.  Also the thank you toggle switch on top left of dash. Above oil gauge does not trigger anything off. Also all the gauge light sockets with 2 wires are not working,but the gauge lights with a single wire work. Harness is in great shape not hacked up.
https://www.bigmacktrucks.com/topic/55062-r-model-cl-lamps-not-working/
Clearance light switch out here turns outer  bullet clearance lights on each side as well as the clearance lights on the mirrors
Dont think the US has clearance lights on mirrors like in Australia ( but could be wrong there)
Paul
  • 3 weeks later...
