Fuel pressure
CV7132005
From what I remember the Original style ETECH engines came with  60 psi overflow valve, there latter came a 100 psi valve that solved some rough idle issues in a few UPS trucks we saw. The ETECH overflow valve has a barb on it for the plastic fuel return lines from the head/injectors. This is a easy way to tell a ETECH engine from a CCRS/ASET engines. Plastic line= ETECH. No plastic line =CCRS/ASET. Starting in 2002 with the CCRS  on through the to end of the ASET engines the the fuel valve opened at 60 psi. So fuel psi should be at 60 + at idle and go up as rpms increase. If psi goes down as rpms go up you got a problem.
  • 3 months later...
