If no one has the manual here, check over at Just Old Trucks.  Member "dieselsteveo" may be able to help you out.
http://forums.justoldtrucks.com/Default.aspx
Okay, thanks I will try them next.
8 hours ago, carlotpilot said:
can supply you with just about anything you want to know about a 220 maybe eve n some pieces
Oh great thanks. The just basics like coolant capacity normally and normal oil capacity. And if a spin on oil filter adapter kit exists for it? Also the same with a coolant filter.
How about in frame rebuild kits for these engines do they exist if I want to freshen up this engine?
kits do exist as do most other parts they can be a little hard to find but they`re out there. I will get some info together and get it to you
