dash doesn't lighting up
Have you check the fuses?
  • 1 month later...
  • 3 months later...
Our 2002 CL did that and it ended up the circuit board in the dash was bad.  Installed a new circuit board which worked for a while, then the factory solder  where the connector plugs in on the back failed.  Soldered that back in and it has worked since.
I bought 1/4 turn light sockets of ebay with pigtails on em , wired em all together and connected to the wire in the dash plug. This eliminates the circuit board.  Works great and dimmer still works.
https://www.ebay.com/itm/10x-T10-168-194-2825-927-928-W5W-Light-Bulb-Wire-Wiring-Harness-Sockets/281850050064?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
